Battery Cover
TonyG
Shepherdsville,KY
2017 Laramie
Was wondering what the purpose of the blanket/cover that surrounds the battery is for. Anyone have an idea?
kad
Hudson Valley, NY
5.7L HEMI
Keep the heat out in summer, keep it in in winter and absorb acid in case of a catastrophic failure.
-K
hotrod45
Home
Keeping the battery clean, offering some protection against inadvertent shorts, keeping shirt sleeves off the battery and out of the lube on the posts, are a pretty good start. There are likely more, too.
kad
Hudson Valley, NY
5.7L HEMI
Here's a question, does anyone know what year they switched from using the felt style cover to the padded cover? My '14 has the felt style.
-K
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Change in temp is a battery killer. Battery blanket is pretty effective at reducing cold to hot, hot to cold temp changes.
hotrod45
Home
-K
My '17 has a felt cover, slightly roughed up by chipmunks.
kad
Hudson Valley, NY
5.7L HEMI
Yeah, same with mine. :) That's why I asked, I was considering replacing it with the padded style. May need to stop by the dealer and see if they have one in stock to measure. The parts catalog actually lists both for my '14, with the padded one noting "750 amp" and the felt one noting "800 amp".
-K
Fitz-0518
Veteran 66-68
Central California
^^^yes same on my 2018. Pretty heavy firm 1/2" thick formed material. Carpet padding is a good description.
grizzstang
Calgary, Alberta Canada
-K
Kad nailed it, this is what they are for but IMO they don't do any of these things well.
I take them off anything I own so I can actually see the battery.
kad
Hudson Valley, NY
5.7L HEMI
Do they make a better one?
Well, I thought they did (the top one in the picture) but I stopped by the parts counter at my local dealer on the way home and he was able to look up the measurements on the two. It appears that the other one is for the diesel trucks and is smaller (by about 1.5" on the longest side).
-K
Reactions: JB1
McBroom
Denison Tx
Hemi 6.4L
I’m with ya @JB1 mine looks like carpet padding too. Real thick padding
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Off Road.
Reactions: JB1
