Jpaschal
I have a 2018 Ram 5500 that the low voltage light keeps popping up constantly and has been for the last 3 months. Batteries are new. Four months old. They both load test at 1000cca. Alternator is new. It was replaced 2 weeks ago. Battery sensor is new. Just replaced today. There are no codes in the ecm. Nothing is indicating there is a problem with the charging system except for the constant annoying DING every ten seconds while the engine is running. There is no corrosion on any wiring. I have even load tested the passenger battery from the driver’s side cables and vice-versa. Batteries still passed load test. Message center on dash will read 13v and still display the low battery message. A volt meter will read 13.7v while driving and still the message will display. There is no reason for me to think there is a problem with the batteries actually charging. The truck can go hours on acc and running my laptop with no problem starting up. What else would cause this message to falsely pop up?
