Battery low voltage message
roadrnnr
Vermont
A Bad battery will cause all kinds of weird things to happen. When my OEM finally went the Cruise would stop working, remote start would not work, etc.
I just replaced a two year old Die Hard AGM that Advance auto tested and swore was fine. ( and would not cover under warranty I might add) yet It kept draining once the cold set in. I tested my whole system every which way you can to no avail. Finally just replaced battery and all was good.
Battery's these days are a crapshoot. May be your only problem if nothing else is found
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
I have not seen it mentioned before if battery’s need to be registered to allow proper charging voltage and temperature to be monitored
Flooded Lead Acid battery vs Dry Glass Mat technologies are going to have different temperature tolerance’s I would suspect auxiliary battery systems to require the same care.
Jambro
Hendersonville NC
6.7 cummins
I have a 2018 Ram 5500 that the low voltage light keeps popping up constantly and has been for the last 3 months. Batteries are new. Four months old. They both load test at 1000cca. Alternator is new. It was replaced 2 weeks ago. Battery sensor is new. Just replaced today. There are no codes in the ecm. Nothing is indicating there is a problem with the charging system except for the constant annoying DING every ten seconds while the engine is running. There is no corrosion on any wiring. I have even load tested the passenger battery from the driver’s side cables and vice-versa. Batteries still passed load test. Message center on dash will read 13v and still display the low battery message. A volt meter will read 13.7v while driving and still the message will display. There is no reason for me to think there is a problem with the batteries actually charging. The truck can go hours on acc and running my laptop with no problem starting up. What else would cause this message to falsely pop up?
mauntie256
conn
6.7 cummings
try replacing the mega fuse on the passenger side battery
mauntie256
conn
6.7 cummings
try to replace the mega fuse on pass side battery i had the same problem dealer replaced the alt 2 times didnt work i bought the fuse for 18$ at the dealer all good now 250 amp square with ceramic middle its the front one
VTOD
Eagle, ID
6.7 Cummings
I Replaced my Batteries because the truck wouldn't start. It started fine, but I had a low voltage error. I took it down to Autozone and their computer said everything was fine. No issues found. But the truck still had this issue. The owners manual indicates that the truck shouldn't be driven if the low voltage error is present. I had read about the $18.00 fuse on this forum, and that is what it was. It was in stock for $16.99. Quick fix, for what was a frustrating problem.
Thanks for the help. Here is a photo of the square.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Do you have a forum link to more on this issue?
Dean2
Near Edmonton
So, this thread is almost a year and a half old. Did you find the problem and if so, what was it.
