Bed noise
Long Islander
Summins 6.7
When I go over bumps I hear a noise coming from the bed. I can't explain it anymore than a rear sound of metal to metal.
Any ideas?
Jdchambersjr
Cypress, Texas
Broken spring would be my first guess. I have one and get the same clanking noise over bumps.
B1G R3D
Central Pa
Any ideas?
Just dealt with the same thing. Have someone jump up and down in the bed while you are under it. Mine ended up being the rear control arm bushings.
L
Long Islander
Summins 6.7
I will take these tips and report back.
What was the cost of repairs you two?
Sent from Samsung S5 using Tapatalk
WhiteExpress
Midland, TX
I'd guess the shock sleeve came free and is rattling around on the housing / shaft.
The sleeve on my '13 is already rubbing on the lower housing.
Cheap junk factory parts!
Jdchambersjr
Cypress, Texas
Haven't fixed mine yet. I never haul much anymore. That would be different if I carried a load regularly. As it is, it just makes an annoying noise over big bumps.
B1G R3D
Central Pa
About $6 for some grease from auto zone and a hour or so.
Like i said get a friend to jump in the bed and get the truck bouncing and look around underneath. Easiest way to find it. Good luck. Let us know what you find.
L
Long Islander
Summins 6.7
It was a loose step rail!
stevenmicheal
