Bedlined... rockers.
blueram03
Looking to put the bedliner on my rocker panels...
A) Will the DIY kit from an auto parts store suffice?
2)How far down do you go for prep? Just scuff to hold? Or deeper?
iii) I'm competent, just not experienced.
Look forward to hearing from you all... I get all my best ideas from you guys!
Stangshcky12
Oshkosh, WI
5.9 Cummins
DIY kits work great, herculiner is a popular choose but there's several other companies that even put it in rattle cans
Just scuff away the gloss, don't go to bare metal
Use a surface cleaner before and after sanding/scuffing
I like your outline form too haha
WhiteExpress
Midland, TX
Make sure there is no shine. Use a good wax remover to assure a good bond.
ramhunter9
P-Star Jeep Wrangler
LOL @ Trup ..
Sand the clear .. that scuff pad .. throw it away .
Use Hurc .. its the best .
Medium grit sand paper blah blah ...
Yes I have done a few ...
Few pics of my hurc jobs ... All BUT the white ford are my trucks ..
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Did mine!! Just take.your time with the prep work.
Sent from my VS920 4G
Stangshcky12
Oshkosh, WI
5.9 Cummins
Becareful with wax and grease removers vs. surface cleaners
You want a surface cleaner, I never really realized there was a difference before
Dingo
I did mine earlier this week. I used Duplicolor bed armor aerosol cans. It has been a couple of days and is pretty solid. I only did the bottom 6 inches and the bumper because it had some rust.
Hollabakzach23
Lafayette, IN
I did mine at the beginning of the summer and I used the duplicolor. I've also used the hurc which works well. Just stay away from the rustoleum kit I think it sucks. Just personal opinion though obviously! I would recommend getting the applicator kit for it though it makes everything go on much smoother!
RompinRam
Hoffman Estates, IL
4.7 Magnum
Just did all mine! Not hard at all. Just prep prep prep. Don't get lazy with it haha.
B
blueram03
Thanks! Ya'll are a great help! like I said, competent, just not experienced. Good to have some of the latter on here.
Hollabakzach23
Lafayette, IN
Good luck with whatever route you decide to take and shoot us some pics when you get it all done
B
blueram03
Nice! I thought about doing that as well... I love the blacked out look. Does that stuff stick well? Or is that all about prep too... Lol.
Hollabakzach23
Lafayette, IN
Prepping it is easy just clean it up real good. Just make sure to lay it on thick coatwise put on like 4 or 5 coats on each wheel
Budakane
Northern VA
345ci Hemi
Beware!!!!! Once u go plasti-dip, you may find a way to spray on everything...including wives, dogs, etc...lol
Hollabakzach23
Lafayette, IN
Hey! I'm not an addict I tell ya!! But I'll be back in a bit I gotta go finish PD my overhead console with some leftover dip I found in the bottom of a storage container in my garage... Lol
stevenmicheal
