Ramsportrocks
is there anyone else that makes a variable rate rear coil spring with '0' lift??
I don't need a lift I just need extra capacity..
Pretty much TTC's are about it for increased capacity springs. Haven't seen any others offered...unless you go with air springs.
TTC 1211 give you about 3/8 inch unloaded if you can get past the 0 lift required bit.
