kowbel11
Looking to pick up a diablo tuner and pcm for my 17 sport. Wondering what would be the best upgrades. Thinking about long tubes but what else? Is a cai really worth it?
I made my own cai. It was worth the $30. I wouldn’t put down more than that having done it and knowing the results
How did you do it? Have pics/thread?
More you must tell us.
How you did this, we gotta know
Blue Streak Pearl off-road package
Search for "Thad air". Thad tested it out w/ the stock intake. After he used the 5.7 stock intake he swapped it for a 6.4 stock truck intake & liked it a little more
Google,chrome and Tapatalk are all a no go. If your using this set up post a pic...
What did you make it out of? The biggest problem with intakes is heat soak, if you are using a metal intake tube after 15 minutes of driving you are doing nothing but sucking hot air.
Myself I am using the old style S&B w/ the coolant overflow tank moved over to the driver's side more & the scoop cut a little shorter for air to have a straight path to the intake through the grille
