Gary's Hemi
Is there an kit offered to relocate coolant overflow tank?
If so where?............Thanks
No. I had Jay turn off my AGS in the tune, I removed the shutters & I moved the factory coolant tank over to the drivers side more. I just moved it over to where the bolt is on the top pass side of the shutters & used that bolt then drilled & tapped for a 1/4" bolt on the bottom support for the bottom of the tank. It worked out perfect. The tank fit there great. I cut a new hole in my plastic shroud for the cap.
