Best Level For Air Ride
Sportznut
2019 Laramie
It seems like the best quality ride for pavement driving is the "normal" level. Would you fellow air riders agree?
Sent from my SM-N920V using Tapatalk
soapy
Northwest
6.4 hemi
it is the only setting without restrictions also.
Ramit355
Minford Ohio
2019 Ram Laramie Sport 4WD
Yes I would agree it is as well. This is 2nd truck I have had with air ride....my 2014 Would default to nornal ride hieght and remain there until I exceeded 62 MPH for a short time then lower to areo ....then when under 25mph or stop it would default back to normal and indicate as such.
Can you guys tell me what happens when you set your new 19 to normal? I go to Normal then go on highway over 62 it goes to areo and stays there no matter what speed I go back to or stop it just stays in the aero and not in Normal unless I set it to go into normal manually. Any one else have the issue with their 19?
Sportznut
Sportznut
2019 Laramie
Did you get your answer?
19Streak
Ontario
My 19 defaults back to normal everytime I come to a stop.
Ramit355
Minford Ohio
I have an issue with mine dealer still trying to solve. It will not default to Normal. it always defaults to Aero and when I check or uncheck aero in settings it makes no difference. Bad part is dealer has no experience with the 4 corner suspension.Dealer is researching to find out why? It will work properly on all manual settings but will not default automatically to normal ride height. So currently while they research it I just put the truck in Normal Ride and leave it there.
Ramit355
Minford Ohio
No just the last one.....My understanding as how it should work and did on my old 14 was from exit it should go to NRH then over 62 mph for a minute it should go to aero ...then below 25MPH or a complete stop it should go back to NRH and Exit/Entry when I choose so below 25 MPH.
Right now it will go to exit/entry by me setting it which is correct but then it goes to aero and stays there after 25 MPH unless I select NRH manual. Its weird ...truck has no codes what so ever as if its normal...lol.
Sportznut
Sportznut
2019 Laramie
That is weird. I have gotten to the point I just leave it in normal. Rides nice.
But of course it is always fun to hit the fob to show friends.
I would assume the dealer will reset yours somehow. Good luck and let us know how it ends up.
Ramit355
Minford Ohio
Will update once they figure out what the problem is. One of the guys at the dealer was in favor of replacing the suspension module. They also are looking to see if a flash may be available but with no codes being thrown its difficult to find a flash fix they are saying.
Ramit355
Minford Ohio
If I select Normal it deploys fine.....but when I exceed 62 mph it defaults to aero with our with out aero checked in the settings menu and stays there until you either select exit/Entry or normal modes.
Ramit355
Minford Ohio
Dealer took truck in a few minutes yesterday to do a scan from the ODB port. Tell me they have no idea how to get it to work in auto mode like its supposed to,very annoying to run around in aero mode all the time I forget to set it back to Normal mode..lol.
CHADWICK PHILLIPS
Nashville
2019 Ram Laramie 4x4
Hemi etorque
I've noticed twice now that if I use the fob to lower the truck the next time I drove off it stays in entry mode no matter what speed I hit.
Ramit355
Minford Ohio
Thats odd....I never have tried using the fob yet....But I will and let you know what I find too.
Ramit355
Minford Ohio
****** Update on the Air Suspension not defaulting to NRH. ********Went to a different dealer today who fixed it in an hour. The tech. rest all additives and re flashed. Works normal now.
The advise here to go to a different dealer is very good advise for any issue one dealer cannot resolve! :)
DAVECS1
Peoria IL
Hmmm, well mine stays in Aero too, but I actually like that functionality. I was always annoyed by the fact my 2015 would raise up at a stop light.
JohnnyMac
SouthWest Washington
2018 1500 Laramie
3.0 EcoBurner
Sad it's come to that, but great advice.
Ramit355
Minford Ohio
yes Sir! It did how ever go back to sticking in aero mode again....The 2nd dealer then opened a "star case" had the truck for a week and its fixed or working right since I got it back Wednesday. They said someone at factory set the modules for the Air in Metric not standard causing Suspension modules to not reset properly. It been great last three days so far!
Ramit355
Minford Ohio
I let it go like that for awhile until it stuck in E/E mode with air shocks all way down. At that point When I tried to raise the suspension manually it would not come out,luckily I was not pulling a trailer with a good load on it!
DAVECS1
Peoria IL
Yea I have towed twice and have been a bit worried, but once in tow mode it seems to hold normal.
