I run GTX CSP Minis and have been happy with them because most of the cheaper LEDs from Amazon would require you to modify the stock housing because the dust shield on the back would not screw back in due to the large heat sink on those cheaper LED bulbs. My recommendation is if the GTX bulbs are too expensive try to find something on Amazon without a fan unit on the back of the headlight bulbs, and instead find one with a more compact design. Other than that, the light output is pretty good for still using the stock headlight assemblies but if you want something different I've had my eye on the Morimoto XB / Alpharex Nova units. Little pricey though, definitely not under the $100 suggestion.
