Best nonslip Bed Mat?
djtomy
destin
I'm looking for a Bed Mat that will hold my toolbox and supplies from sliding around. I have the factory plastic Bed liner on my 2011 1500.
I heard Mopar has a good one.
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
BedRug would be perfect for what you're looking for. Had one in last pickup and the first thing I did when bought the 14. Extra benefit is it's great on the knees if you have to crawl around in bed.
It's spun plastic that feels like short nap carpet and simple to clean at self serve car wash or garden hose,
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Mopar Mats were produced by BedRug, when they first started out.
Just a suggestion:
if you have a Drop In Bedliner, they tend to collect dirt, leaves, etc. under the liner.
Then it rains, the paint scratches a bit & rust can develop
Cleaning under them annually might be a good practice.
Any bed rug made of rubber, should hold things in place, even with the bedliner
ColesRAM
NE FL
5.7 V8
I bought a DEE ZEE DX87015 bedmat off of Amazon
Another vote for bedrug here. Check your local dealer,as when i bought both of my bedrugs,they were the cheapest,but that was quite a few years ago.
Daw14
I second the horse stall mats ,heavy duty .
Scottly
Safety Harbor, FL
HO 6.7 Cummins
That cheap $99 bed mat that Rough Country makes (Yea, that crappy company) works well.
djtomy
djtomy
destin
I'll look into bedrug, I like the texture of carpet. I also have a roll n lock bed cover that helps keep things dryer.
Alos Found this
Dee Zee DZ86917 Heavyweight Bed Mat​
TigreST
Canada
Alos Found this
Thats what I have and like it very much. It sits on top of the factory spray in bed liner. I also have a removable home made "cargo board" that reduces the distance between tailgate and box for easy storeage of smaller items, like 20lbs propane cylinders and such. The following link may provide more idea's for you cargo cotnrol in the box, check it out. There is also pictures of my "cargo board" and other members systems. https://www.ramforum.com/threads/bed-management.147432/
KPMH
Chicago Area
Alos Found this
The Dee Zee is the exact one I have. Fits perfect and nothing slides around. Good quality mat. Definitely recommend it. I thought about carpet mats but things like plastic tubs will still slide around on that IMHO.
JetDoc
Post Falls, Idaho
3 liter EcoDiesel
The problem with any sort of bed mats is that when exposed to weather, they tend to collect water and debris under the mat, and that promotes rust. I always take my new trucks to the local Linex dealer and have one of their spray-in bed liners done. They can lay down a rubbery pebble-grained surface that grips tool boxes and other stuff, and also protects the floor and sidewalls of the bed from dents, scratches and corrosion.
nhcaveman
When I bought my 2011 Ram 1500 Outdoorsman Quad Cab I bought a rubber matt from Cap World for $85 for my 6'4" bed. Almost 8 years later when I bought my 2018 Ram 1500 BigHorn Crew Cab the bed was a 5'7", Having totaled the 2011 I sold the Undercover Classic, which also came from Cap World and kicked in the matt, which was still like new, very well made. The 2018 I put on a Leer Cap, and installed a Bed Rug, I really don't think the Bed Rug was worth the $500+ it cost. Also I don't think the Leer was worth what I paid for it either. So my current 2021 Ram 2500 Tradesman Crew Cab came with a 6'4" bed, factory spray in liner and I added a Undercover hard folding Armor Flex cover. I wish I kept the rubber matt since as this is also a 6'4" bed and I wouldn't mind the extra protection. So, go to CAp World and buy their quality matt, but don't get the Bed Rug, it get's dirty and doesn't really offer any protective value.
ExpressRules
Southern New Jersey
BedRug has a thick rubber mat on bottom, so water doesn't make it to bed surface.
NASCAR
Calif.
Diesel 6.7L Turbo
I’ve used the same $40 stall mat in 3 trucks in the last 20 years. These things won’t even show wear. Easy to trim to length. 48” wide.
regulator54
Hamilton, ON
2016 SLT Plus, Crew Cab 4X4
I put the MOPAR rubber mat in the box on top of the factory spray in bedliner. Works like a charm.
IDSandman
Idaho
I’ve been running the same DeeZee bed mat mentioned above in my last three trucks. Thing is bomber and nothing slides around on it, well unless you slam the breaks or get real sporty in your driving.
