didnt know you could do this on WXI's website. it sheds some light on a few things. just for info it looks like the flow rate is slightly less (even though its bigger) on the "57899" as well as the by-pass valve setting is significantly higher compared to the stock "57060". also for some reason the 57060xp does not list the burst pressure and the 57899 does not list the Beta-ratio.
You would really have to do some research before changing form the OEM or OEM equivalent filter.
also the 57060xp is actually used on a lot of american v8's.
the chevy
5.3L
6.0L
6.2L
7.0L
as well as the little 1.4L
Part Applications List
57060xp
Part Number: 57060XP
UPC Number: 765809216976
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.45 (88)*
Outer Diameter Top: 2.921 (74)*
Outer Diameter Bottom: Closed:
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 12
Anti-Drain Back Valve: Yes
Beta Ratio: B2=20
Max Flow Rate: 10-12 GPM
57899xp
Part Number: 57899XP
UPC Number: 765809222076
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.74 (95)*
Outer Diameter Top: 3.675 (93)*
By-Pass Valve Setting-PSI: 16
Burst Pressure-PSI: 275
Max Flow Rate: 9-11 GPM
Catalogs
My lesson has been learned.thank you guys for the help. im sticking to OEM/equivalent oil filters.
