bnadito
Greetings from Germany!
I'm just about to order a RAM1500 from the current model series. I would like to put some bigger wheels on it.
Plan A:
At first I thought of 35 tires in conjunction with the 3.5 inch kit from roughcountry https://www.roughcountry.com/dodge-suspension-lift-kit-31430.html
Plan B:
Alternatively, I would simply mount the largest possible tires that fit without modifications. 285/65/20 should fit without changing anything. Can someone tell me which tires are that?
Or is it enough to install only 2 "spacers from the front so that I can mount the 35" tires?
My goal is to improve only the look. Since the vehicle is really used a lot and over long distances, the comfort and roadholding should be as unchanged as possible. So I drive longer distances with 90mph.
Plan A:
Plan B:
