So sounds like I at least need 2 level in front. Will 33/12.5 fit the stock rims? Or are they two narrow? (The rims)
I was also wondering the same thing. I'm torn between 2 tires the BF Goodrich K02, or the **** Cepeck but the ***** come in 275 65 20. When I called tirerack customer support could not confirm if those tires would fit on the stock rim or cause any rubbing. I'm also trying to stay stock for now also.
I would stay away from 12½" tires unless you change your UCA's
I'm running 285x65x20 which are 11.6" wide. I can just fit my fingers between the upper control arm and the tire. Anything wider than 285x65x20 on stock wheels will rub with out a spacer. I also have Bil's set at 2.1"
