Bilstein 5100 Installed
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I just finished the installation of Bilstein 5100 shock absorbers on my 2014 Longhorn 4X4. The truck has about 39,000 miles. I use it a lot for towing our 30 foot 9,000 pound Airstream. The installation went fine, the old nuts were very difficult to remove from the end of the shock shaft, but I finally got them off.
gofishn
Iowa
hemi 5.7L, 345 cu in
PICTURES!!!!
gofishn
Iowa
There they are
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Nice looking truck, I am not usually a fan of brown but that 2 tone looks awesome ! And a Airstream that is the best trailer out there :)
Cableman
Longisland
How was it swapping coils over to new shock? Id like to do this as well, i see some do the upper control arm also.
Longhorn1500
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
It was not bad, took me maybe six hours to do both. I removed the tie rod end and the upper ball joint. Not too bad a job, you have to make sure the brake hose does not get strained; some people remove the caliper and hang it out of the way to avoid this threat. As mentioned above, one of the hardest parts is getting the nut off the end of the old shock. This nut is buried in the spring structure, so a socket is needed to get to it (at least on mine as the whole area was rusted, so an open end wrench did not grip the nut well enough). I inserted a socket on the nut and gripped it with vice grips and then was able to hold the shaft with a small socket through the one holding the nut. A pain, but it worked. I suppose the whole nut and shock end could be ground out if they are too rusted together; thankfully I did not have to do that. The next hard part was getting the bolt through the bottom mounting point on the shock and through the lower control arm, it did not line up very well, so I had to use a bottle jack to push the bolt up while pounding it in, this worked fine and was not too bad. Swapping the coils over was easy enough with spring compressors.
Joes1500
San Antonio tx
Looks good.
How do you feel the 5100s changed you ride compared to stock at 2.1 ?
Longhorn1500
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
Looks good.
I installed Bilstein 5100's in the rear first and noticed that it seemed to control the bouncing when towing a bit better than the stock shocks. I have not towed yet since installing the fronts, but the ride without towing seems a bit firmer. I also like the ride height better.
Longhorn1500
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I believe it is a Leer with the solid window option. Nice cap I have the same but with the slide windows. If you get one get the liner and a bed rug .
What @JoeS said. It is a Leer 100XQ. This model comes with the liner. And I do have the Bed Rug too.
They did a fine job matching the paint.
Cableman
Longisland
Yes, i did... after watching two YouTube videos where they put the washer on wrong, I made sure to do it right (according to the instructions).
Just ordered a front set, 87 bucks a piece!
Whats this washer you guys are talking about?just so i have no surprises during install.
Longhorn1500
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
It is the washer that goes on the shaft. So the order is washer, top spring housing, then nut. It is all laid out in the instructions that come with the shocks. Some people put the washer under the nut (as you usually do with bolts and nuts), but that is incorrect as the shaft can then force its way through the spring retaining housing, not good.
No members online now.
TheM4rxxx
