I was just being stubborn haha.Thanks, I have no problem with cutting up a Harbor freight wrench.[emoji23]
Good luck! I couldn't be happier with the bils all around.
Thanks for the advice. Did your truck with set at 2.1 need any adjustments?When I first did my Bils at 2.1, the install guy told me to drive it for a day or two, so things were all settled when you get the alignment ... My alignment guy agreed
Thanks again!That was a long time ago, but if memory serves, the adjustments were very slight ... My alignment guy is very picky ... I credit him for a good bit of my good tire wear
What level are your front set at and still stock UCA's?
2.8What level are your front set at and still stock UCA's?
Sent using Tapatalk
Interesting, I keep hearing problems with the mevotechs. I plan on running the stock UCA's until they crap out then I will throw in the Zone UCA's.2.8
Had Mevotechs, but one of the ball joints went bad. So I went back to the stocks. No issues.
Sent from my SM-G975U using Tapatalk
It was my fault. I forget to keep it greased and one froze.Interesting, I keep hearing problems with the mevotechs. I plan on running the stock UCA's until they crap out then I will throw in the Zone UCA's.
Sent using Tapatalk
View attachment 169632 2.8 front and BS 5100 + 1.0 Rear Spacer
