Bilstein 5100
troy rowe
manitoba canada
Currently have level kit in front on 2012 ram 1500-Planning on getting the bilstein 5100 ride height adjustable set to 2.1 or so and keep my current level kit on top of that.Anybody here done that yet?Thanks
JB1
Houston, Texas
Its not recommended to add a level spacer on top, however if you don't adjust the 5100's up to high and kept it all to around 3-3.5" overall lift you might be ok. The main concern will be your CV shaft, steering angles and probably the UCA as well.
ThunderMug95
North Prince George, VA
If I remember correctly a few months ago a guy had that set up. The pic of it had everything cranked at pretty extreme angles. If it were me, Id just go 3” body lift and keep your level.
Gary2
S Jersey
I did 1.4 on the Bilstein's ( after trying every setting ) and a 3" BL . That was so the shock absorbers could still absorb and not pass on the shock to the truck which more noticeable with higher settings .
troy rowe
troy rowe
manitoba canada
ok thanks-I'm going moderate setting on the bilsteins and keeping the spacer,will see how it goes-no time to do job yet
ThunderMug95
If your current level kit is a spacer on top of the stock coil assembly and you add Bils at 2.1 your net front height increase will be significant. Im at 2.1 and it leveled my truck with about 1/4” rake to the front. If you do your plan, your going to be 1.5-2” taller in the front compared to the back with your CV and ball joints at severe angles. So you may experience some vibration or catastrophic ball joint failure with bulldoggin it down the road.
Just beware....
troy rowe
troy rowe
manitoba canada
I will put it 1 notch above factory setting and I think it will be ok-front end is all brand new-if I need i will get different upper control arms for ease of alignment-cv angles right now are ok with 3.5 spacer
troy rowe
troy rowe
manitoba canada
All done-works great with bil's set at 2.0 and 1.5 level kit on top of that-driveline angles/cv/ still beautiful.Front floor to fender lip is now 39.5 inches, rear is 41
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Curious what the CV angles look like up front
ram1500rsm
Trabuco Canyon, CA
You went a little low with this camera angle, try to snap the pic little above that.
Is this with a spacer on top of the strut, or a preload spacer + Billies at 2.1?
Aside from a better CV angle, the other interesting pictures will be your UCA angle at rest, and just for chit and giggles, lift the truck from the center front, and take a pic at the angles of your UCA with the struts at full droop...
ram1500rsm
Trabuco Canyon, CA
I'll post my angles with my Rancho setup tonight for you to compare, i have the Zone UCA's, and my struts doesn't have any spacers, so i'm not overextending my struts at full droop.
ram1500rsm
Trabuco Canyon, CA
So here you go, UCA at rest
45367491965_6b9d7af7b8_h.jpgUntitled by Wrangler RSM, on Flickr
45556591044_d0652829b7_h.jpgUntitled by Wrangler RSM, on Flickr
CV angles at rest
45171481614_7a38decb4d_h.jpgUntitled by Wrangler RSM, on Flickr
Now lifted from the front, letting everything droop with tires off the ground
46229910392_532bf8b8dd_h.jpgUntitled by Wrangler RSM, on Flickr
UCA's at full droop
32408523758_8821fedf2b_h.jpgUntitled by Wrangler RSM, on Flickr
45556499544_8bc3c44790_h.jpgUntitled by Wrangler RSM, on Flickr
CV angles at full droop
46229916372_05a3e50804_h.jpgUntitled by Wrangler RSM, on Flickr
46280040351_6d9a9707a2_h.jpgUntitled by Wrangler RSM, on Flickr
Most important things for you will be to check how your UCA BJ's look like at rest and full droop, same for the CV angles, if you have a spacer on top of the strut, things might be bad for you stock parts depending on the size of that spacer, there seems to be some nice front room in this trucks though, i guess because of the factory air suspension can lift things 2" from the normal resting position, and FCA may have designed some wiggle room in our trucks geometry so we seem to have some more room to play compared to other applications that don't have such feature, but past 2" though might be a different ball game.
GIJoe2010
Killeen, TX
Droop looks good all around to me. Thanks for the pics.
