Binding noise in front end
Mike49321
Portland, mi
HEMI 5.7
I haven’t jacked it up to check it out yet, but am tonight after work. Was getting off the highway the other day and when I started going there was a very pronounced binding/popping noise from what seemed to be the front passenger side. I was far from home...ended up getting it home without it doing it again. Then I took it for a little ride to see if I could get it to do it, and it did it quite a bit. Sounds like something is binding. I can feel it slow the truck down when it binds. It’s not constant. Binds and then pops. Doesn’t really seem to matter which way I’m turning. Does it driving straight sometimes. I didn’t have time to jack it up, but did notice my outer cv boot is ripped
2008 ram 1500 4x4
anyone else had anything like this happen before??
M
Mike49321
Portland, mi
HEMI 5.7
I should also mention that it doesn’t seem to matter if it’s in 4x4 or not
I’m just confused. Doesn’t seem indicative of bad cv joint or wheel bearing, as far as my history with them going bad
M
Mike49321
Portland, mi
HEMI 5.7
Just jacked it up. Wheel bearing is toast. Tire barely spins and there is in and out play
