Biometric handgun safe
Tpettit
TAPPER
WA
Pretty sure I've seen posts on here before about this, just can't find it. Looking for suggestions on a high quality handgun safe that will fit in the lower front seat center compartment. Any help would be appreciated.
Different Drummer
North East
Pentastar V6
I have one that is a perfect fit. I believe it is "Gun Vault" model Microvault.
I will take a look to make sure.
Travelin Ram
I’d like one of those as well.
I’d be interested in hearing feedback from owners on the reliability of the fingerprint scanners. I have no personal experience with safes, however a relative has several because he has children and he’s told me the print scanners are finicky sometimes.
daveray9
I have the gunvault center console, not fingerprint tho just the combo.
Safe itself is awesome, not a fan of the fingerprint ones.
Different Drummer
North East
Pentastar V6
I agree, I don't care for the fingerprint style either. Mine has four finger grooves that you must enter a correct sequence of touching with your fingers. Also has a key for use if the 9V battery goes dead. It is a nice fit in the lower console. One issue is that there is no place to connect the anti theft cable to in the lower console. I probably could do some drilling or come up with a work around if I wanted to. It basically is to CYA if you are forced to leave the firearm in the vehicle or are traveling through one of the ********* States. When legal the firearm is more readily available to me. Not in the gun vault. I am pretty happy with the Gunvault.
Travel safe
TC
Central TX
scott lass 18
rocklin ca
2010 ram 1500
on ebay cheaper a screw in and lock easy to put in ! not sure in california ok but hay no one says no its all locked up and a cable I put in it cuz have to have one hear going to safe ? dumb bolt cutter just take it anyways daaaa !
Travelin Ram
I have a question for those using these: do they have enough foam or anything else inside to prevent the gun moving and changing orientation? As in washboard roads, no roads, or minor collisions?
I’d only use one if it would keep the muzzle oriented towards the engine compartment regardless of movement by the truck.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
I have one of those gun magnets in mine that keeps it secure.
Different Drummer
North East
Pentastar V6
I have never noticed any movement occurring in mine. In fact, I have at times placed two handguns in the vault simultaneously and when opening they had not come into contact with each other. I was not off roading however.
TC
Central TX
Magnet for sure. You can orient gun with barrel facing down underneath passenger seat or underneath drivers seat, whichever you prefer.
