Blstrick55
Same. I’ve used Castrol Edge since I bought the truck used last year.
Even if you consider the 1400 miles different, the wear is trending down which is what we are seeing. Anyhow, I would be happy with the first run which is the higher wear, that is normal hemi wear, the second one is better then normal hemi wear imo. The first run was just redline? No additives?
It is also the time where I'd expect wear to continue to trend down. I bet if you keep running uoa's it will only get better.
Look at that lack of sheardown @ 100C. Notably in SC over summertime which is hot all the time. Did you do any towing?
Thanks for posting - awesome oil.
Here’s my latest, 5w-30 Redline with the “big”RP filter.
Gave this one a pretty good test, ran her pretty hard with the oil already having almost 8k on it, last 1k miles or so involved a good bit of towing with sustained oil temps around 230*-240* for a couple of hours. Pretty happy with the report.
@6.7CumminsDrvr - kind of a weird handle for a '14 Hemi driver?
I'd have to look back on the other UOAs but most of that was RL 5w30 which is 11.9holy hell just when I spoke you see that incredible uoa, and we see 0w30 still good visc. How many miles? What was each column starting weights if you don't mind posting Corey?
6 mos to the day in winter, I'd sat that 0w30 redline is a winner.
