blisteins vs leveling blocks
skirider
So i wanna do a 2.5 level. I am now stupped on using bisteins or hbs spacers. Is it true some of the negative things blisteins states about spacers on there website.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Do not believe what one company will say about anothers products. They will say anything to get you to buy their products. As far as leveling you truck out go with what you can afford. Blocks are perfectly fine and tons of people use them safely every day. All shocks do is limit the travel by bottoming out on the down stroke, possibly prematurely wearing out. DO it right and get blocks and make sure they are installed properly, you will be very satisfied.
gearhead
I am assuming you meant to post this in the 4th gen lifted section but I would say the Bilsteins are a nice was to go. You can simply adjust them down and you don't have to worry about some spacer stuck above your coil. It is the way I would go, but as with any spacer style lift you will be limiting the amount of drop you have by doing so. Pro's and cons both ways.
