Go with high hths low noack oil, at least 5w30, and see if it's less. Thinking it may be rings and not valves. If it is rings, you may get lucky with a cleaner. It could be carbon buildup or corrosion, second one is not fixable without cracking her open.
Redline si-1 boroscoped in 3 vehicles with similar results, rf member here hemi395 as well. Allthough a follow up test was weird as the carbon looked as if it was back, dunno. More testing needs to be done. 2 bottles did a real nice job on the outer ring of piston.
A good way to go is redline si-1 in gas tank with your current oil before you change it. si-1 ends up in oil, thus changing oil when your done is a good idea. And sea foam though vac lines. You just might free carbon on rings, if so it may actually fix the issue w/o cracking it open. Note I said might, nothing to loose really.
