Bluetooth Audio
KeithS
Colorado Springs, CO
Hello everyone. I've noticed that when I talk through Bluetooth on the truck that the audio only plays over the front left speaker in the dash. It sounds horrible! I looked in the settings but can't find a way to change it. Has anyone changed the Bluetooth audio to play over all the speakers, or at least two? On my other vehicles and on aftermarket systems you can change it if you want. Any help would be much appreciated.
Keith
dmalonecentral
Tempe, AZ
5.7L HEMI® V8
I saw somewhere that it seems to be a bug because the person describing the same issue said that if they were on FM radio and made a phone call it came through all speakers.
Afrats
Colorado
Mine was doing that until I did the last update. Now all is normal again.
Mandride
North Carolina
What update did you get for the 2019? Mine is just bought this month but I do not see anything about an update. I have the same issue. Switching to the FM Radio didn't help.
Mandride
North Carolina
Okay I just installed the update. Much better Phone service. no more scratch and static in the calls. Lets hope it continues to be that way.
ksn240
How did you get the update?
Mandride
North Carolina
It came down shortly after I activated the Sirius service. Not sure if that had anything to do with it. I suspect not. I also selected system info a Couple times. It will tell you to leave truck on while it updates. About 30 minutes
Sent from my Pixel 2 using Tapatalk
pkillian
