Body control module
bill91194
Travelers Rest SC
I have a 04 Ram 1500 5.7 Hemi
The dash lights and dome light quite working all gauges work fine just can’t see at night any easy fixes
bill91194
bill91194
Travelers Rest SC
I thought of that but the light switch didn’t have any effect and it doesn’t control warning lights
McBroom
Denison Tx
Hemi 6.4L
Do the tail lights work if not it’s the fuse
Blue Streak Pearl off-road
bill91194
bill91194
Travelers Rest SC
Yes all the exterior lights work properly just done and dash lights including warning and turn signal indicator lights
SYKRAMMAN
Banned
Jersey shore
06 Mega
Maybe cluster itself, but before throwing guessing money at it, have it diagnosed by someone with a quality scanner, usually cost an hours labor, $100-125
justin13703
MD
A scanner isn’t gonna help with some lights out on an 04. The trucks weren’t that advanced back then.
You did check all the fuses right?
SYKRAMMAN
Banned
Jersey shore
06 Mega
Maybe not the bulbs itself but definitely would tell if there’s communication between moduals to diagnose if the cluster is bad. But since all the cluster lights went out at once, it can only be a few things, like cluster itself, bcm, pcm, wiring harness, bad grounding. All witch can be diagnosed by quality scanner, not a parts store scanner.
bill91194
bill91194
Travelers Rest SC
I am lead to understand that cluster is BCM but if get one from junk yard the mileage will be off any way to change it
mikep345
