Itsme71190
Did a search and yielded 3 results. One was going in the direction I needed then when cold.
I installed 1.5 spacers and am getting a clicking noise. I hear it a low speeds and turning. I took them off and drove around the block and the noise was gone. Re installed the spacer and added a little bit of lithium grease to the hub/spacer and spacer/wheel. The noise went away for yhe next test drive so I thought I was good to go. Noise is back the next morning. I have aftermarket wheels with the relief/pocket cuts.
Are they just adding too much stress to the hubs or cv axles?
