Bora Spacers
BrazenHaven
Las Vegas, NV
5.7 with eTorque
Just installed some Bora 2” spacers on my Rebel and I have to say I’m pretty impressed. No change in ride quality. Makes the rims stick out about 1 1/2”.
4f84c87a467f5c30d7bbc260e3173dfd.jpg16b1aaa807378a34f895fcaf5b2b7b6d.jpgff1ce7fcfd63aff13f42f2da888f7876.jpgc1b416227f239538e992bdb9486e9b49.jpgc6ef312f54fc0d97edc833babc0cdd3c.jpgc147b2135f5cb6ab6e69697c08d7b64a.jpg
2019 Ram 1500 Rebel
N-Fab Epyx Bars, Bak Revolver X2, Mopar EVTS
Pro-tech bed liner, Flowmaster 40, Undercover Swing Case, Husky Mud Flaps
BrazenHaven
BrazenHaven
Las Vegas, NV
5.7 with eTorque
Most definitely. I have read a lot of people complaining about eBay and Amazon knockoffs. Worth the extra money for quality.
2019 Ram 1500 Rebel
REBEL12
Grand Blanc Michigan
5.7 E-torque
Brazenhaven
I just ordered a set of 1 1/2 spacers. I really like how your look but didn't want then to stick out that far. Thanks for posting some pictures. Next I'm going to do a leveling kit
BJSwizzle
Edmonton Alberta Canada
2019 1500 Sport
5.7L
What size? I put 2” spacers on,
35x12.50R20LT tires, truck is levelled, and did not fit, had rubbing going on that I couldn’t solve
BrazenHaven
BrazenHaven
Las Vegas, NV
5.7 with eTorque
If your truck is leveled and you have 35s those spacers aren’t going to fit. You essentially have 37s on your truck at that point. You would need a 4” lift to fit those.
BrazenHaven
BrazenHaven
Las Vegas, NV
5.7 with eTorque
The rebel comes stock with 33s. Putting the 2 inch spacers on mine I get rubbing at full lock at the center of my mud flaps. If I didn’t have those on they would clear no problem. Triple checked and they don’t rub anywhere else.
BrazenHaven
BrazenHaven
Las Vegas, NV
5.7 with eTorque
Yeah 1.5 you won’t see any rubbing at all. It would be the equivalent of putting a 33x12’s vs 33x12.5. With a 12.5 I really need a level because the 1inch factory lift from stock rams just isn’t enough. Haven’t justified cost for that. I would rather just do another 2in or 4in of lift.
REBEL12
5.7 E-torque
Here is a side by side comparison with and with out spacers 2 2019 rebels even the same color20190426_203430.jpg
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I had 1.5 Boras on my truck but they rubbed the mudguards at full lock turn each way so they were gonna get pulled off eventually. Aside from that, they didn’t look too good with my new Michelin Defenders. lol. Looked good with the bfg all terrains, tho.
corneileous
Podunkyville, OK
Put on my 1 inch spacers. Very easy to put on. I didn't have to cut my studs.
From a previous thread talking about these things, I was under the impression that anything less than one and a half inches would require trimming the studs. My Limited wheels have fairly deep pockets on the inside of the mounting flanges but I never did measure them to see if there might be enough space for a half inch worth of studs to fit in there or not.
The 1.5’s did look good, tho. With the factory wheel flares, they made the wheels fill out the fender wells nicely.
Maybe one of these days if I can get these sold, I may try the one inch spacers.
olyelr
Kewadin MI
Hmmm, how in the heck did you not have to cut the factory studs when they stick well beyond the spacer?
dalvingl
US
Brazenhaven
I got 1.5" spacers on my '17 and they are perfect.
Sent from my SM-N986U using Tapatalk
