NicksGarage
My 2009 Ram 1500 came with the basic RES radio without bluetooth connection, no backup camera, no steering wheel controls. This week I installed a Boss Audio BE9ACP floating screen unit I got from Crutchfield. This is a single DIN unit with a 9" floating screen. Wired Android Auto and Apple Carplay. No CD/DVD capacity. Fairly basic functions but planning to use Android Auto for most things. Nice thing about this one over other floating screen units is this allows you to angle the screen side to side so I have it tilted toward the driver side. They make smaller ones and a larger 10" one but the 9" screen is a good fit with the truck and plenty big enough and you save a few bucks. I got the whole setup from Crutchfield for $400 delivered. It came with a adapter mount, wiring harness and antenna adapter. Not cutting or other modifications to the truck required. I also got a tailgate handle backup camera from Amazon and connected that up. You are supposed to tap into the parking brake so that the radio will know that you're in park in order to do some settings but I got around that by connecting a ground wire to that input that I can connect when needed. The radio adapter has a slot below it for storage and this is where I routed the USB cables and microphone into there along with the ground for the parking brake signal.
It was very easy to install except for the Crux harness adapter. There are two wiring setups depending on whether the vehicle has an amplifier or not. I assumed mine didn't and wired it that way. When installed, sound only came out of the front speakers. Then I tried the alternative wiring which has you only connect the front speaker wires from the radio to the rear speakers on the adapter. That caused the sound to only come out of the rear speakers. After several calls to Crux, which didn't inspire confidence in the product, I finally found a review on Crutchfield that solved the issue. They mislabeled one of the connectors that you had to plug in one way for with an amp and the other without an amp. So I had to rewire everything back to the first way and now everything works. I used WAGO connectors in the end just so I wouldn't waste so much time soldering. Made a real mess out of the harness. Fortunately there is plenty of room in the area behind the unit to stuff all this wiring mess in there. I wrapped foam about the plastic control unit and the connections to prevent rattling.
Eventually I'm going to add a front camera to it. I've been using wireless front and rear cameras on the truck since I got it but the license plate mounting of the rear one wasn't ideal, especially at night as the license plate lights would make it hard to see anything.
