Hey Loudram, i've got a dumb question about your Weigh Safe hitch... The scale on the hitch tells you the tongue weight, right? You said you are in the 700-850 range. Then the app tells you the Distributed Tongue Weight range - the image you posted earlier was 1,750. You then crank the nut on top of the hitch until the scale is at that target weight.
My dumb question is this: does this weight - 1,750 lbs - count as tongue weight? Does it count as payload? Is there a way to calculate where that weight is going? Front axle? Rear axle?
I'm looking for a travel trailer and i don't want to overload my 1500. My GVWR is 6900 and i scaled my truck empty with a full tank of gas - 5,720 - so my pay load is only 1,180 lbs...
Thanks much for your insight!
