Bouncing on certain interstates with stock tires
D
DJElliL
Utah
2020 Power Wagon
Wow, thanks for all the help everyone! I didn't even think about the PSI, I wrongly assumed that it was normal guidance for those sized tires, I even asked the dealership specifically and they said it was normal.
I'll experiment with some lower PSI and see what I get.
UTAHPWRWGN
Hurricane, UT
6.4L Hemi
With HD trucks the OEM's are obligated for liability reasons to use tire inflation settings that will guarantee safety at maximum load (cargo + towing). Because those numbers are so high an empty truck will ride like dog **** because the tires are ridiculously overinflated.
olyelr
Kewadin MI
I bought my pw brand new from a dealer with over inflated tires…and im not just talking overinflated from a pressure i think is correct, im talking overinflated from what the sidewall max reads.
Sunnysideup
Las Vegas, Nevada
Yea Im wondering the same my tires have been at 65 since I got this truck
So everyone is running around 40?
Dean2
Near Edmonton
The tires come aired to 80 pounds from the factory so they don't flat spot from sitting and for purposes of transport as previously mentioned. When the dealer PDIs your truck they are supposed to air them down to the door sticker. Good dealers do, poorer ones don't. Have to ask yourself, if they miss the tire pressure, what else did they miss on the PDI check list.
Here is a link, this specific one is for the Duratracs I run, same size as yours, but you can find other makes by scrolling down to the Tire make list and click on yours.
https://tirepressure.com/lt275-70r18-tire-pressure
My truck sticker says 65 rear, 60 front, I run 50 (chart says 10,720 load split evenly on all four tires) all around based on the loads I carry and at that pressure I am over max GVW. I could drop to 40 all around for everyday use based on my normal loaded weight.
I get a low tire warning from the TPS every time I start the truck and the yellow tire warning light is always on. The dealer is not allowed to change the TPS limits. You can reset TPS limits with Alpha OBD but I have never bothered to get one, and the security cable that you need to run it.
Dean2
Near Edmonton
So, everyone is running low tire pressure for daily, when loaded crank the pressure back up?
Close, we try to run the pressure appropriate to the load. Gives better ride, better traction and much longer tread life. Too much air hurts performance and longevity as much as too little.
soapy
Northwest
6.4 hemi
I ran the entire state of Utah yesterday in my 2022 GMC regular cab short bed and can tell you that the worst roads for bouncing was around Salt Lake. 40psi in the tires but a prominent bounce going through Salt Lake. I don't think my S class MB would have tamed those bumps.
UTAHPWRWGN
Hurricane, UT
6.4L Hemi
Yeah, that's not the truck, that's the spacing of the seams in the concrete being poorly designed in relation to vehicle wheelbases.
