I knew I should have paid more attention in physics class.... You've totally lost me. By increasing the action of the WDH, weight is taken off the hinge at the hitch point. Some goes to the truck, some to the trailer. The result is a lighter tongue weight which results in a great propensity to sway. What am I missing?
Sway isn’t about how much pressure is applied at the ball. It’s about how much mass is in the trailer and where that mass is located.
We tend to use pounds and kilograms interchangeably but there is a difference between mass and weight. Mass is how much of something there is. Weight is how much force you are exerting. If you weigh 200lbs it means that due to your mass (kilograms), and the earths gravity, you exert 200lbs of force against the ground.
What will cause your trailer to become a pendulum (swing back and forth) is it’s mass, and the location of the center of that mass. Like flipping a whip back and forth with a ball attached to the end vs the ball being attached next to you hand. The further the center of mass is from the pivot point the more pronounced the swinging will be (in this case both the hitch ball and trailer tires act as pivot points).
If the center of mass is behind the trailer tires the trailer will have a tendency to start swaying left and right. Tensioning your WDH does not move any mass, thus it won’t effect trailer sway. Only adding/removing/moving cargo forward or rearward will do that.
The WDH uses spring bars to pull the truck and trailer frame into alignment and thus concentrate more weight (pressure against the ground) to the furthest most contact points (truck front axle and trailer axles).
Think of a gymnast doing a full split. So much so that his feet are almost off the ground and most of his body weigh is on his butt. Now he starts using his hip muscles to pull the legs together. As he does, his butt starts to rise and his weight shifts to his feet. He didn’t move or redistribute his mass, he simply changed the pressure points. Thats what WD hitches do. Shift the pressure points.
The truck rear axle is his butt and the trailer axles and truck front axle are his feet. The WDH lifts the rear axle and shifts weight/pressure out to the other axles. In fact if you cranked your WDH far enough eventually you would lift the rear tires of your truck off the ground.
I hope you can picture what I’m trying to describe. Applying adequate pressure between each tire and the ground IS important for maintaining steering and control. But “sway” is about trailer center of mass. The 10-15% tongue weight rule is a measurement intended to tell you where the center of mass of your trailer is.
