Brake and traction control dash indicators on intermittently
broma345
Hello all,
I have a 2011 Ram 1500 5.7l 4x4 crew cab Laramie. Recently the brake and traction control indicators on the dash have been coming on intermittently, usually at relatively low speeds 40-55ish, and then they go off again a few minutes later. I've checked out the normal brake system stuff, pads front and rear are fine, rotors not cracked/warped and fluid level is good. I removed the rear rotors also and checked the ebrake pads and mechanism and it seems to be functioning and fine. While i was there i also replaced the rear wheel speed sensors since they are pretty inexpensive.
Has anyone else seen this or does anyone have any ideas?
Thanks!
B
broma345
Just in case this helps someone, this ended up being a bad brake fluid level sensor in the master cylinder reservoir. Sensor failed continuity test with a multi-meter. The sensor is part of the reservoir itself, but changing the reservoir is a straight forward job.
