Brake Light bulbs
ctdodge
Bristol, CT
2017 Laramie 1500
Does anyone know if the CHMSL bulbs are LED from the factory. I have a '17 1500 Laramie which has LED brake / turn signal lights. I haven't opened it yet, but I'm going to replace the gasket and while it's open I can replace the bulbs with LED if necessary. Looking in the manual it says some are incandescent and some are LED.
Thanks
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
They are not. I also believe there is a risk with putting in some LED's will give a tail light error message as the sensing circuit for the CHMSL is on the same tail light circuit for light out monitoring.
St. Marys, GA
I just installed one of these in my 2018 PW, and they are definitely LED - the housing is clear, and the unit has both white and red LEDs.
There were two configuration options in AlfaOBD - one to enable the camera, and one to designate the lights as LEDs.
stevenmicheal
