Moparchild
Got a 95 3500 that the brake lights and turn signals quit working.all fuses are good and the brake light switch is good.any suggestions? Thanks
Should be a ground wire under the bed, probably driverside. Check that. Also, trailer harnesses are common for corrosion issues. Should also be a flasher relay but being that you also have brake light problems I don't see that being the issue.
