Brake pedal goes to floor
Chick
V10
I have a 1998 Dodge 2500 with V10. I got in it to go to town, and the brake pedal does to the floor, Checked the whole truck and could not find any fluid leaks. Bought a new master cylinder, bench bled it, installed. Bled it on the lines, and the pedal still goes to the floor. Not losing fluid. Back brakes are adjusted. What is going on? Proportioning Valve? Anti-lock?? Thanks!
MADDOG
Out Exploring Arizona
Brake booster maybe.
I'd have to agree with SYKRAMMAN...if that diaphragm in the booster case goes bad, or you don't have sufficient vacuum to the case, the brakes will pretty much be dead.
C
Chick
V10
The brake booster just makes it easier to depress the pedal. This pedal just goes to the floor. Once it makes it to the floor, the brakes will stop the truck.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Correct but like maddog said, if the diaphragm is shot, you’ll loose vacuum and result in sponge brakes.
C
Chick
V10
I don't have sponge brakes. The pedal just goes to the floor. If you pump it, it will stop about 1" from the floor. When it goes all the way to the floor, it will stop. I am sure it is either the proportioning valve or the ABS, but don't know how to diagnose which one it is.
SYKRAMMAN
Banned
Jersey shore
06 Mega
The only two things that give your pedal pressure are master and booster! If it was proportioning valve then it would pressurize fluid to wheels at different pressures causing lockup on said wheel/wheels but you would still have pedal! If it’s the abs, it would be the module or wheel sensor but again you would still have pedal, maybe you got a faulty master, I’ve had it happen right out of the box. If I’m wrong, somebody will correct me. Maybe you didn’t get all the air out, maybe there is a tiny pinhole you can’t see. Could also be a vac leak somewhere, jmho.
SYKRAMMAN
Banned
Jersey shore
06 Mega
I learn something new everyday, great research, keep posted on progress and good luck.
golfcarr
Did you solve your problem? If so, what was it ???
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Rather than adding onto an existing thread, I would highly suggest you start a new thread in your specific forum: https://www.ramforum.com/forums/3rd-gen-2002-2008.43/
You'll have better luck that way.
Truth be told, 9 times out of 10, a brake pedal that drops to the floor is the master cylinder. Rarely it's a hose or line, those you can easily spot as they leak.
