I did put one in from local parts store. Two to three weeks for an OEM. I have one on order from a dodge dealer.Did you adjust it properly? Are you wondering about if your wiring is any good? I don't get it.
Is it a Mopar switch or a pre-crapped-out parts store one? If you have a scanner tool (or even an ohm meter) hook it up with the continuity wires and push in/out a bunch of times. Sometimes like on one i was working on, it would work most of the time but 1 out of 20 times it wouldn't 'make'.
Today would be five times.I have to wonder ..
How many times have you turned the ignition on & off ?
since you replaced the switch
