Davood
What does the ORC do to the ABS in a rolloer situation?
Little background, I have resurrected a rolled-over beast 2017 4x4. Near the final stages. The vehicle starts and I have fixed most of the problems and cleared the associated codes. I have a few lingering ABS codes and a brake pedal position monitor "short to ground" that denies me from the ability to shift out of park.
1) the brake pedal sensor was broken so I replaced it (does this need to be calibrated after replacement?)
2) ABS code 004211 (active Brake pedal) along with PIC4E from the PCM and (0032 and 00132 and U0110E all pending) the left front wheel brake line was kinked. So I straightened it out while waiting for the replacement line, and have since replaced the line and bled the brakes.
what has not changed is the pedal behavior (and of course the in-ability to shift out of park). The pedal is nice and firm with the Ignition off, once started the pedal travels a lot, almost to the floor. Also, if I start the truck with foot off the pedal, the display shows P solid green lit PARK. but foot on the pedal the P starts flashing, still not able to shift. with the IGN off the pedal gets firm again.
Thinking AIR in the ABS from when the truck was ass over teakettle. I have yet to do a full bleed on the system. DOes it make sense that air got in the system if someone stomped on the brakes when rolled over?? DOes the ORC do anything funny to the ABS when there is a rollover situation???
