jholaway1971
To start off my brake pedal feels really good but brake warning light in the dash stays on so I was told to change the ABS sensor on the rear end so I did that and still the light stays on. So I change the back brakes shoes they were worn but not beyond the point where it causes drum damage. I adjusted them and the front brakes and rotors have already been changed before I got the truck by Midas in January 2014 (found the receipt in glove box) so I was told to bleed the brakes at each wheel so I did and bled the master cylinder too. I even checked the parking brake switch (basic two copper pieces making contact) and that looks fine.
I also checked the switch (black plug) at the combination valve as seen in this photo:
https://lh3.googleusercontent.com/-.../geI1ZhDIwGQ/w737-h553-no/20140314_113526.jpg
I also would like to know what is this that has brake lines going to it from the combination valve with the white plug:
https://lh6.googleusercontent.com/-.../Wchbs2GpK30/w737-h553-no/20140314_113539.jpg
My oldman says I should buy a new master cylinder even though I have great brakes.
