brake
1995 ram
1995 ram 1500
hey guy im new and i have some problems with my brakes. i have replaced all the rubber brake lines and the calipers. now i have no bake pedal pressure when the truck is started. i have bleed all the lines after replacing every thing. im lost in what it could be
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Have you touched the master cylinder? Bled it? Replaced it?
scoose
Atlanta
2007 1500 sold, 2011 1500 5.7 sport sold, 2016 6.7 2500 4x4 sold, 2014 2500 5.7
OK dont take any of these questions personally....your initial post is a little vague.
Do you know how to bleed brakes properly? ( again dont be offended...youd be surprised )
Have you checked the calipers for leaks and proper function?
Have you checked the master cylinder for leaks and proper opertion?
1995 ram
1995 ram 1500
none taken i know a lot of people that think they know how to but dont and i have had three people look over it for leaks but they or my self have not found any. i have not looked at the master cylinder.
crazzywolfie
under the truck
are you sure you got all the air out of the lines and kept the reservoir topped up? most times i usually gravity bleed things as i am going and usually end up with a nearly full pedal without any work.
1995 ram
1995 ram 1500
i have not done that. im going to get the master cylinder tomorrow
1995 ram
1995 ram 1500
just have to do it in four inches of snow
CMSBusDriver
