broke security lugs
JcsMI
MI
How do I get a broken security lug out? Its the one that tanks a special long socket and its a long lug. It broke two. Theres about an inch of lig left in there. The security socket no longer fits. The propane torch keeps flaming out in the hole.
diymirage
Banned
If you got a set of brass balls kicking around, you could just remove the other lug nuts on the wheel and go for a ride
J
JcsMI
MI
Well one broke on the passenger front and the other on drivers front. I had the passenger front off two weeks ago but a shop tightened them after. Same shop did a brake inspection. They found seized calipers and said my rear pads had 2000 miles left. But when I went back they said they discovered all of this by looking through the rim. Is that possible to determine these things by looking through the wheel? I ask because my lugs and not all coming off. And I wonder if they did take all four off but tightened way too much. Not sure how I'm gonna get these off. Maybe I'll see if I can cut it with an air chisel. The drivers will let socket slip over the broken one but the passenger does not. But even then it still does not budge. I have been using Liquid Wrench and PB Blaster. The passenger side I got 7 off and the 8th broke. The drivers I got four off, one broke and three aren't moving. For whatever reason my Mapp Gas torch flames out when I put the flame on the lug in the hole. Still trying to get this onn. I have a new tire for the passenger front but the tire shop could not get the lugs all off. I have sprayed several times with liquid wrench. Now PB Blaster. But I need to get the broken ones off most.
turkeybird56
Central Texas
IMHO, U need to find a new shop there ref brakes/tires. Posts #5 & 6 combined, may be your best choice. I have used a cold chisel and cut off locking lugs before, but that is a monster way to do and U also risk doing some damage, to the point of even having to replace the stud affected. U could also buy a HD nut splitter and attempt to split off the part still on there. U can torch those nuts all day, but unless U burn them off, U still have to get something on the part to remove. You might be able to go to an autoparts store and buy (1) BIG splitter instead of a set. TBH, for the price, I would just buy the set. Good luck.
diymirage
Banned
I cant see that tool working unless the lugnuts stick out
And if they do that...he would probably have steel rims and he wouldn't need security lugs
62Blazer
Midwest
make locking lug nut removal sockets. They are pretty common. Harbor Freight sells a kit for $40ish. You could also call some local tire stores as many have experience with this, and typically have a set of the removal sockets on hand. See if they would be willing to take the one broken lug off.
turkeybird56
Central Texas
I cant see that took working unless the lugnuts stick out
Good catch had to think on it. Just another option. I chiseled a set off of a RAM and it took forever but eventually got them off.
The ole slightly smaller socket jammed onto nut had been used too. They got YouTube videos out on how to defeat a locking lug quick.
Central Ohio
2020 Classic
Do not ever go back to that shop again. no, you cannot measure brake pad thickness by "looking through the wheel" If they did an honest brake inspection, then they must have cross threaded the nut going back on and kept on it with the impact till it was seated.
Can you access the head of the wheel stud from the back side? maybe grind off the head and punch the whole wheel stud out?
Indynick
Detroit Area
I used an air chisel to remove locks that would not budge, even with the key. Had to do all four of them. You will need a high-quality air chisel, that will allow you to slow the hammers to just one or two at a time, to get a deep bite into the metal. A cheap air chisel will just be on or off.
After that, you can start looping around. I don't remember if I had to replace the studs.
Ken226
Washington State
I hold a big steel nut over the locking lug nut with some pliers, then mig weld the center of the nut to the locking lug nut.
For the ones that are countersunk pretty deep and hard to access by other means, anyway.
Then it's pretty easy to spin off.
Similar to the method used for removing broken exhaust manifold bolts.
tape some aluminum foil around the immediate area, then spray it with a little anti-spatter to protect the wheel paint from any spatter that might occur.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
If you’ve ever seen how to remove a broken stud by welding a nut onto the end…. and backing it out of the hole…. A similar thing might work.
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
I also go with the welded nut as the most likely to work. With the least agravation.
LouieBlues
Senior Moment
North Jawga
2017 Sport 4x4 SCSB
Welded nut's also works if the OP has a welder handy. I've got a Hobart... but...
stevenmicheal
