Broken Headlight Adjustment
flashover95
I broke my headlight adjustment (turned it too far). How can I repair it? Pix would be helpful. Thanks.
crazykid1994
Can you post pictures of yours and how it’s broke? May be more helpful to see how it’s broken.
F
flashover95
ill add pic tomorrow. i was trying to raise light beam and turned screw too far. projector light dropped down and wouldnt raise again no matter how many times i turned screw.
OC455
Central NY
Sounds like you turned the screw too much and might have stripped it. Might have to separate the light and see if you can get it remounted.
Is this the part ?
I have never looked at mine
bottom attaching bolt
F
flashover95
seems like the end is a ball and its out the socket
hunterdan
SE PA
2019 classic
Turn the adjuster the opposite way, it'll force the ball back on to the socket. Once you hear it pop, stop so you don't pop the other one off.
OC455
Central NY
If you can use your finger and put it in the hole for the light bulb, pull back on the reflector part and then go the opposite direction with the screw to get it back on.
