Broken in Half?
06 Dodge
Forest Grove, Oregon
6.7L CTD
And for the flatbed truck at Home Depot, here's a closer look of the frame and where it is shearing.
So 10+ years from now if anyone is buying used you know what to look for to see how hard it was used/abused. I'm sure there will some patched up frames out there one day.
Nothing a good chuck of solid steel and a few bolts will fix it right up better then new...
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Wow I wonder if welding on the flatbed to the frame had anything to do with it rotflmao
The flatbed is bolted to the original bed mounts. This is NOT a cab & chassis truck. It had a dually bed on it and they removed the original box and bolted on the flatbed.
4xdad
Edmonton Alberta
2015 powerwagon
I will take your word for it but it looks to me that it was welded but it’s hard to tell on my phone I wasn’t there so I don’t know but I do know it wasn’t loaded properly
4xdad
Edmonton Alberta
2015 powerwagon
It looks like they welded on both sides and if you look at the front part of the frame it looks like it has been burnt where the steel touches the frame maybe someone will be able to get a better look at it
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
For further evidence it was a pickup is the fuel filler. All they did was detach it from the dually bed and strapped it up on the flatbed.
For the welds, the factory frame has welds. If I get a minute I'll try to get pics of that area for you on my dually.
Randy Grant
Ellensburg, WA 98926
VLG6963
