Broken manifold stud
badfish888
Va beach
2012 hemi express
So my truck failed a va inspection for an exhaust leak. They said a bold had broken. When i looked the back stud on the pass side was gone.
After i pulled the manifold it was broke clean off at the head
badfish888
badfish888
Va beach
2012 hemi express
Had to drill it and use an easy out
14hemiexpress
6.4l
Thumbs up I had 2 broken i got 1 via easy out second one had to be welded as to not mess up the head I couldn't get a stright drill on it. Not a fun job but you can now knock it off your bucket list.
DILLIGAF
Canadian Forces
Canada
Dodge using sub part bolts to save money :)
Love corporate greed, And from the amount of post about this on forums im surprised they still get away with it.
Bferren
Did the same thing last night. Top back bolts on both sides and 2 more broke when taking manifolds off. Just welded a nut on all of em and came right out. Let's hope these new ones don't do the same down the road.
pickupman66
Tennessee
I have this job pending to be done in October. Not looking forward to it. I know I have broken ones on the driver side. I dont have a welder so Im hoping I can get to them with a right angle drill along with reverse drill bits and EZ outs.
pickupman66
Tennessee
Good news, got all 8 out. Back two had just the head broke so the stud was sticking out. Front top was broke right at the engine. Drilled tiny and worked up to the ez up. Out it came. I heated all of them before wrenching. New ones going back in.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
Why put stock bolts and manifolds back in? They suck and warp and break constantly. After all that work I would upgrade... headers and stage 8 bolts or ARP manifold bolts.
pickupman66
Tennessee
U gonna buy the headers and rework the exhaust for me?
Hipps2000
Hemi 5.7l
If you can't then I would at least buy better grade bolts than own stock cause they break all the time If you have to stay with manifolds. Seems like a lot of hassle to have to do again.
pickupman66
Tennessee
I agree. But had bought better ones than stock but they were the wrong ones. Last minute trip to dealership as no other parts places had them. It is what it is.
Hipps2000
Hemi 5.7l
Good luck! You did a great job! You are lucky the manifolds were not warped as ina few other threads.
wstacy3
This isn't warrantied?
NorCal
Depends on your factory warranty, age, and miles. I was emailing back and forth with a tech at a local dodge dealership, because I'm fairly certain I have at least one broken bolt, and he told me broken bolts and warped manifolds are covered as long as warranty hasn't run out.
pickupman66
Tennessee
No warranty. And they know darn well about them. Parts counter knew the issue well.
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Bring your factory exhaust manifolds to your local engine machine shop and have them resurfaced before reinstalling
Resurfaced manifolds
New manifold gaskets
New bolts and studs
Problem solved
pickupman66
Tennessee
We resurfaced them ourselves. Cleaned up very nicely. And all new gaskets.
freekie
You may not fall into this category but there is a Federal Emissions law that says the Manufacture must warranty any emissions related parts for 8 years / 80,000 miles. Exhaust manifold bolts would be part of the emissions system I believe.
https://nepis.epa.gov/Exe/ZyPdf.cgi?Dockey=P100AU05.pdf
"Emission Control Parts
1. Exhaust Gas Conversion Systems: oxygen sensor, thermal reactor, catalytic converter,
dual-walled exhaust pipe
2. Exhaust Gas Recirculation System: EGR valve, thermal vacuum switch, EGR solenoid,
EGR spacer plate, EGR backpressure transducer, sensor and switches use to control EGR
flow
3. Evaporative Emission Control System: purge valve, fuel filler cap, purge solenoid, vapor
storage canister and filter
4. Positive Crankcase Ventilation (PCV) System: PCV valve, PCV solenoid
5. Air Injection System: Air pump, diverter, bypass, or gulp valve, reed valve, anti-backfire
or deceleration valve
6. Early Fuel Evaporative (EFE) System: EFE valve, thermal vacuum switch, heat riser
valve
7. Fuel Metering System: electronic control module (unit) or EFI air flow meter, computer
command module or mixture control unit, deceleration controls, electronic choke, fuel
injectors, fuel injection units and fuel altitude compensator sensor, bars or rails for EFI
or TBI systems, mixture settings on sealed fuel mixture control solenoid, diaphragm or
other systems, fuel metering components that achieve closed/other feedback control sen
sors/loop operation switches and valves
8. Air Induction System: thermostatically controlled air cleaner, air box
9. Ignition Systems: electronic spark advance timing advance/retard systems, high energy
electronic ignition
10. Miscellaneous Parts: hoses, gaskets, brackets, clamps and other accessories used in the
above systems
Emission Related Parts
These are examples of other parts of your vehicle which have a primary purpose other than
emissions control but which nevertheless have significant effects on your vehicle’s emissions. If
any of these parts fail to function or function improperly, your vehicle’s emissions may exceed
federal standards. Therefore, when any of the parts of the following systems are defective in
Questions and Answers 4
materials or workmanship and have failed in a way that would be likely to cause your vehicle’s
emissions to exceed federal standards, they should be repaired or replaced under the emissions
warranty:
1. Fuel Injection System: fuel distributor
2. Air Induction System: turbocharger, intake manifold
3. Exhaust System: exhaust manifold
4. Ignition System: distributor, spark plugs, ignition wires and coil
5. Miscellaneous Parts: hoses, gaskets, brackets, clamps, and other accessories used in the
above systems.
DILLIGAF
Canadian Forces
Canada
Both mine were done under warranty 2 days before I installed my headers lol... :flipthebird: Mopar
They put on 2 new ****** OEM manifolds along with all the same factory crap that caused them to fail.
07MegaCabRam
Chandler, Arizona
6.7L CTD
My wife had this same issue on her 2006 Durango. Thankfully the back to snapped right at the manifold flang (outside) so when I removed it, I had a good 1" of bolt sticking out that I was able to get a vice grip on and get it out.
vitbvc
