rpr
- Mar 29, 2014
- 303
- 61
- Location
- GA
- 2014 Ram Limited
- Hemi 5.7
The factory air ride on my 2014 Limited is brutally harsh. Until now I just figured it was the nature of the beast but I really don’t see many others reporting this. Slightly harsh which is perhaps expected for the air ride is not what I’m dealing with, it’s punishing.
Highway driving is fine, I like feeling the road. But if I go over a speed bump, regardless of how slow, it’s like there’s no suspension at all. The rear suspension is worse than the front in this regard. Drive over mild to moderate water breaks on a gravel road, no matter how slow, and it’s just brutal. If you’ve ever driven a 20 year old John Deere gator which has no suspension down a gravel road, it’s (almost) as bad as that.
I have a 3” PA body lift (which shouldn’t affect suspension travel) and the leveling links. The links could potentially harshen the ride as it does reduce (upward) suspension travel, but I use the links primarily for leveling, so the fronts are raised much more with the links (1.5” to 2”) than the rears (maybe 0.5”), and it’s the rear suspension that’s the worst. I have 35x1250x20 Nitto Ridge Grapplers. Prior to that I had 35x1250x20 Micky Thompson ATZs. Had the same issue with the suspension with both (but I like the Ridge Grapplers much better).
I’m starting to think there must be an issue with it. It subjectively feels like there’s too much air pressure in them. I remember having a muscle car when I was a kid with air shocks and when there was too much air in them it gave the same punishing ride. In fact, the sensation from the rear suspension when going over a speed bump was identical to what I’m experiencing now. “Hop” followed by “crash”, even at ~3mph.
I don’t have much faith in a local dealership being able to troubleshoot this, I’m sure I’ll just get “operating as designed”, so I figured I would start here.
Anyone have any thoughts?
