case closed, congrats
check the level over a couple days, these rfe's do not like low level.
I did this today on level ground and when i got there the trans fluid was in the middle of the dipstick at 140 and was so foamy it was hard to get an accurate level.
I correctly filled it up once it reached 180, only for me to pull over once i got home to check it only for it to be at the correct level now but still as foamy.
I don’t know exactly where to go at this point, this only started when i put in this new valve body and it’s only making things worse now.
I don’t understand how the valve body could leak so bad but have the CVIs read fine, and have no codes for low line pressure.
My other valve body had such a bad internal leak that it caused my 4C CVI to read pretty much 0, and my 2C CVI to read through the roof, yet i never got any fluid bubbling AT ALL with it.
I’m at a loss, and I really have 0 idea as to what to do now. I’ve dropped the pan more in the past week than a truck without issues would have to do in a lifetime, and i’m not really looking forward to having to drop it again to look at the valve body.
I’m convinced there’s something wrong with it as there’s nothing else i can point at. I’ve replaced both filters with their seals nearly 5 times since this has occurred, with 0 change independent of fluid level. Only thing that’s somewhat good is that the trans hasn’t overheated and stays cool while driving.
If i replace the valve body or look at it and find something wrong even after a replacement with the old vb, i’m going to let the trans grenade itself so i have an excuse to vomit the money into swapping in an 8 speed.
