Bully Tuner Acting Up
argray90
NW Burbs, IL
I drove out to my girlfriends dads house today to get a deep freeze and on the way out I took the highway and notice when is get above 65 on the tuner my MPG and wasted energy would freak out. The MPG would jump from 99 to 3 to 11 to 7 to 99 and on like that for anywhere from 20-45 seconds and the wasted energy would jump up and down constantly. Anyone know what's causing this? Thanks.
J-Dub
Hilltop Lakes, TX
i talked to bully dog the other day cause mine is showing i'm getting 65 miles per gallon right now. They said it would be the 23rd before they had another update to fix it. Not sure if that is the reason yours is acting up tho. And anyone that lives near idaho, bully dog said they have to get permission from the local dealer to use a truck for a few days when they are updating and adding options, which makes things take longer, so anyone around there who would like to leave their truck there so they can make some A/C temperature controls so i can add the V6 e-fan would be greatly appreciated
JoshikusIII
Reno, NV
Sounds like a sensor or reading is haywire either in your truck or in BD programming.
phillips66
Illinois
Mine was doing the same thing with regards to the mph jumping all over. I called bully dog and they sent me the A027 update. Just installed it and the trans temperate says 0. I guess they still have some fixes to do.
Sent from my iPhone
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Mine is now flashing from day to night and back every 30 seconds....
JoshikusIII
Reno, NV
Mine is also doing the day night thing but started before I last updated...I was thinking a glitch in the functions settings somewhere.
Sent from my SCH-I545 using Tapatalk
Lhemi
OKC OK
I tried to load A026 but it didn't load. Might try against tomorrow...
HLram
2012 and 2007
Hemi 5.7 in both
I updated mine the other day to try and get rid of the same "light swapping from day to night every now and then". It did not help. Still does it. It actually started doing this before I got the HF tune on the DS. Now that I am just using it as a gauge did not seem to make a difference on it changing back and forth. It has the A026 update and I didn't have any problem loading it on the tuner. I have NOT tried to load it on the truck tho since I run HF. Is that when it doesn't load or is it just not loading to the tuner itself?
