Buying a power wagon just because it’s bad @$$
4xdad
Edmonton Alberta
2015 powerwagon
Exactly buy what you want/need is ape a tow monster no is it a cheap daily driver no but I like mine I think the only thing I would change is the colour
62Blazer
Midwest
For a power wagon type of truck, yep solid axles make sense. For a tow rig, I dunno. IFS makes a ton of sense there, rides better and no death wobble.
Have to say my previous Chevy with IFS was great on the road, towing and hauling. Put 150k on it and no IFS specific issues. Replaced balljoints and wheel bearings once but that is definitely not specific to IFS. It did have larger tires and wider/more offset rims most of it's life. Nothing crazy but the tires were "2 sizes" bigger and the rims were a little wider and little more offset than factory. Never did any crazy off-roading, but hate to admit I haven't done a ton more off-roading with the PW or anything that much crazier! Really like the stance of the PW (straight axle trucks) and the ability to run 37's pretty easy. I have multiple other vehicles that I do serious off-roading with including a another truck with lockers front and rear and 40" tires.
coronajeep
OK
I get 7 mpg's when I am pulling our travel trailer, & about 10 otherwise.. how is everybody else getting 17!?
Please help!
62Blazer
Midwest
Please help!
From my experience, your numbers are more realistic. I have a '16 that gets around 12 MPG empty and around 8-9 MPG pulling a small trailer (likely much lighter and more aerodynamic than any travel trailer).
olyelr
Kewadin MI
Yea, same with my ‘16. For the last 7 years since buying it new its been 12mpg driving empty and 7-8 towing the travel trailer.
The ‘19 and up with the 8 speed tranny was a big improvement in drivability and a bit better mpg’s, but dont let it fool its still a huge heavy truck sucking a bunch of gas. The guys getting 16-17 mpg with them are just slowly cruising around.
62Blazer
Midwest
I could see the 8-speed helping around town because of the lower gears, but not sure it would help MPG on the freeway. The top 3 gears, so the ones you would be using when cruising down the road, are basically identical between the 6 speed and 8 speed. Meaning 4,5, and 6 on the 6 speed and 6,7, and 8 on the 8 speed are almost identical ratios.
olyelr
Kewadin MI
Yes. I think the magic for the 8 speed is the lower first gear ratio and extra gearing between, which allows the motor to be in a better and more efficient range for longer. I mean the 6 speed in mine shifts into second right off the bat and then stays there till like 50+ mph before shifting again…i feel like my half ton has already shifted into 5th or more by then, along with several extra gears on the way to that point keeping the motor in its sweet spot.
Fatbob Frank
Mc Gregor, Iowa
6.4L
Not true...
I'm NEVER slowly cruising around...
After I drag my butt out of our valley and hit the highway I'm usually hauling A unless I see 5-0...
But I'm usually empty too...
I'll say this- after getting rid of my restrictive exhaust and running a glasspacked straight pipe and the S&B CAI the throttle response is crazy fast...
Neighbors probably don't like me much, but I try not to get on it too hard till I'm out of the neighborhood...
olyelr
Kewadin MI
Not true...
Hmmmm…so you haul ass all the time in your power wagon and religiously see 17mpg??? Or you've seen 17 come up once on the evic on a 50 mile trip cruising downhill with the wind at your back?
Got any sound clips?!?!! I would love to hear it!
Fatbob Frank
Mc Gregor, Iowa
6.4L
It must get fairly good on the highway cause it's only getting 8 or 9 getting out of my valley and up to the highway.
I average 15mpgs more often than not if I have to pass a bunch of people...
But I average 17mpgs enough to be happy with it...
Running heavy 35" tires too.
I work 3rd shift so I usually have the roads to myself at night and share it with a bunch of semi drivers on my commute home and they're usually hauling A too...
No interstate here, just good old 55mph so I'm usually running 61 or so...
