radkawi
If you follow the OP you should have no issues. If you run into any issues shoot me a message and I’ll see if I can help
Thanks for the offer sir! All went off without a hitch. Well, for the most part. Had to figure out a way to support the trans to get to the bottom nut for the xfer case stud. Used some wood blocks to support on the crossmember after removing the transmission mount to gain access. From there it was a breeze. Installed the switch and used Alpha about 30 mins before done to give it time to accept the change. Started it and gave the 4x4 system a test run. All performs, engages and disengages error free, as it should. Front driveshaft unlocks and couldn't be happier with the outcome. Thanks for paving the way and letting us all know this works!
