Cab marker lights
Mattx15
Sarasota, FL
2000 1500 Laramie
5.9 Magnum
I recently put a mopar cab light kit on my 04 Cummins, it did not come with any from the factory so it was a new install, I used the two wires on the passenger side pillar to power them when the switch is on. Everything works as it should, only they do not flash on like the tail lights and markers do when I unlock it with the fob, anyone know of a way to get them to flash on the unlock with the other markers?
mtnrider
Georgia
They were never intended to do that even in the factory installed trucks though I wish they would.
You could probably re-wire with a relay off the marker lights to do what you want?
17CrewCab1500
You could probably re-wire with with a relay off the market lights to do what you want?
Exactly. Working as designed. You would need to run a wire from the plug on the passenger side all the way under the dash to the body control module and tap into another wire to make them blink with the tails etc.
