Cabin air filter replace, 2014 3500.
sealion
Homer, Alaska
6.7L Cummins Diesel
I have a 2014 Ram 3500 Big Horn. I watched several YouTube videos on replacement. I got the glove compartment out, no problem. The tabs on either side that hold the long filter cartridge cover in won't budge. I tried pushing them every direction, and used a screwdriver for leverage, they won't budge. And the cover does not have any writing on it. I am thinking my year class is different. Any suggestions?
You probably don't have a cabin filter in your 14 unless you've added it.They didn't start installing a cabin filter in the trucks till i think either 17 or 18.You can add it though,do a search on here for a howto.
Bad Tiki
Rodney Ontario Canada
2020 Power Wagon
6.4L
I was going to order a filter for mine from amazon and they all seem to come with a replacement cover, which I think is for older models to use.
You might find some info there from others who bought.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
The cover should look like this !
The blower box will have a outline of the cover ! You Tub and here have several videos on the Mod.
So a picture of your blower box would help. I had to cut mine out on my 2015 and as mentioned probaly the 2014 needs to be cut out as well !
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
They began installing the Cabin Air Filter in early 2016
My 2016 Ram is a December 18 2015 build
I had the dealership cut the plastic & install the charcoal filter kit, that i bought from Geno's Garage
2009 - 2018 cabs are the same
https://www.youtube.com/watch?v=tXIry6qw3Nc
Zoe Saldana
california
6.4l
You don't need a cover. The filter goes in very tight.
If you really think you need something - put some duct tape over the filter.
S
sealion
Homer, Alaska
6.7L Cummins Diesel
S
sealion
Homer, Alaska
6.7L Cummins Diesel
Aha! That's why it won't release! The dealer noted that it needed to be changed on a recent visit. I will ask him about that.
Thanks.
Daw14
Thanks.
It is probably time to find a better mechanic ,if the dealer can’t tell if it has a filter or not . This would be my last visit to them.
