Jeff Strader
BlackBeauty
- Nov 10, 2020
- 134
- 135
- Location
- Norman Oklahoma
- 2019
- 5.7 Hemi
I've looked but cannot locate the resistor.. the flat panel with two "screws" on your picture is in mine too but they are not screws but screw like nipples made from plastic and permanently part of the flat surface. I also can put my hand through the hole where the motor was to find that on the other side of this panel there is nothing... Maybe one you refer to was a different year ?
Any other suggestions? I will connect the motor to battery directly next, to see if motor works.
Here is picture of what it looks like down there for me.
Sent from my CPH2089 using Tapatalk
Will that small rectangular panel pull down? That is normally the resistor location. It is in that spot for a reason.. It is mounted there so that it (the resistor) gets air blowing directly on it, so that it doesn't over heat and or melt down (or sometimes catch on fire)
